跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
How to remove super glue from between Digitizer and Front Panel?
I had a friend change the digitizer on my Nintendo Switch because it was broken. We got a glass digitizer, and he decided to super glue it back on because we did not have any double sided tape. However, now the LCD is showing issues and I have no way of getting to it.
Does anyone know how I can safely remove the super glued digitizer?
I have checked for options online but it seems like most super glue removers, or acetone, will damage the plastic housing.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Can you try to remove the super glue using Isopropyl Alcohol(Rubbing Alcohol)?
完成的
@andrewsawesome I could, I just wanted more confirmation that it would be the best route given the situation, and that there wasn't any other option I was overlooking.
完成的
@rods012 were you able to remove the superglue?
完成的
添加一条评论
1个答案
已选择的解决方案
so…… you can try and use a dropper and get some alcohol in between the screen and digitizer. and let it sit for a while. the superglue will need to be softened by it for a while. do your best to keep the alcohol out of the screen.
typically acetone is GREAT for superglue but its also not safe on electronics. it will eat the PCB components and layers so dont use it.
the alcohol may work but be prepared to have to replace both components (screen and digitizer)
next time have your friend refer to the tear down guides found on this site they have adhesive strips for sale also
任天堂 Switch 数字转换器更换
如何使用一块预先切好的胶带
i hope this helps. good luck
EDIT:
heres a guide to acetone. since youre not using ACETONE on any real PCBs, YOU MIGHT be able to try it as a last ditch effort. both the alcohol and acetone will need to sit for a while so you should honestly go into this expecting some kind of permanent damage to either the digi, screen or both.
https://keyboardkings.com/using-acetone-...
Electronics Skills图片
指南
如何使用一块预先切好的胶带
难度:
中等
45 minutes - 2 hours
Nintendo Switch 数字转换器图片
指南
任天堂 Switch 数字转换器更换
难度:
困难
1 - 2 hours
这个答案有帮助吗?
得分 2
3条评论:
@logixal Ahmm...so I did the same mistake as Rods Kaden..
But I used Uhu all-purpose adhesive..I don't think its super glue, is it? Thanks.
完成的
@Rainbow no Uhu is not a a super glue but will still require some work to remove. again dont use acetone! unless you can guarantee it wont get on PCBs. let the alcohol soak the adhesive and a heat gun or hair dryer would also help loosen everything up. make sure not to burn anything lol
完成的
@logixal thank you! I will give it my best.
完成的
添加一条评论
添加你的答案
Rods Kaden 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 855
