跳转到主内容
加入维修社区 - 创建账户
第八代 Apple iPad 的维修指南、拆解和故障排除信息,有 Wi-Fi 和蜂窝网络版本,存储空间为 32 GB 或 128 GB。于 2020 年 9 月发布。型号为 A2270、A2428、A2429 和 A2430。
Touch screen not working after replacement
I recently replaced my friends screen after her autistic son shattered it. The first replacement, the touch screen wouldn’t work. I figured possibly faulty screen. I ordered a second screen and the same thing happens. The wording on the screen jumps around and it won’t recognize touch. There are times the number on the passcode get hit but I didn’t touch the screen. I have checked the connections multiple times and everything seems connected correctly. Could something else be damaged that I can’t see? Thanks for your help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
As a repair shop I have seen multiple consecutive defective screens on these models from time to time. Where are you ordering them from? And make sure the cables are firmly connected in place.
这个答案有帮助吗?
得分 0
4条评论:
I ordered off of Amazon. The first screen I replaced worked great, but the son ripped it off after one day:( The two after that don’t work.
完成的
@lindsey3065 try ordering one from Mobile Sentrix. Get the X07 and you should be fine. But now that you mention your son ripped off the second one I'm wondering if he damaged something on the board. What do you mean by he ripped it off?
完成的
It’s not my son, it’s my friends son. He ripped off the screen I originally replaced that did work. I’m not sure how he did it, his mom said he walked up to her with it in his hand. Seeing the first replacement worked, and the next two screens didn’t, I assumed he did something to the board. Just not sure to know if he did?
完成的
@lindsey3065 if you can, post some pictures of the connectors both on the screen and the board
完成的
添加一条评论
添加你的答案
Lindsey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 1,897
