跳转到主内容
加入维修社区 - 创建账户
HP EliteBook 840 G6 的维修和故障排除信息,这是 HP EliteBook 系列中的一款 HP 笔记本电脑。于 2019 年 5 月发布。
My stuff keeps turning on
I have been trying to let it dry since yesterday because I spilt water on it but after. I took pictures to see if there was corrosion it's been turning on by itself. Anyone know the cause of this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @generalramm ,
Just verifying that you have correctly reassembled the laptop and when you turn it on etc and then have correctly shut it down that it turns itself on again at some point without you touching it, is this correct?
When it turns itself on does it behave normally until you shut it down again or does it act differently?
Are you sure that there is no corrosion.
Check the cable connection on the power button board (see p.57 of the maintenance and service manual) to make sure that there is no corrosion in the connector.
You could try turning off the laptop and if it takes a little while before it turns itself on, disconnect the power button board cable and see if it then turns itself on. If not then the problem may be on the button board.
You have to start somewhere with eliminating what the cause may be if you suspect corrosion and none is evident.
Be careful when working inside the laptop because the motherboard has power on it even if the laptop is off so don't slip if using tools etc and try not to touch anything that you shouldn't.
这个答案有帮助吗?
得分 1
2条评论:
I took pictures of my stuff earlier and no one said there was any corrosion. It behaves normally when it cuts on tho the only thing that I can see Is wrong with the computer that the screen is black whenever it's on. As well as the computer cutting on at random times
完成的
@generalramm
You never mentioned before about no display.
Does the display work when you turn it on?
If not try shining a torch at an angle close to the screen when the laptop is on and check for images. They will be very faint if they are there so trying this in a darkened room may help.
If there are images then there is a backlight problem.
If the laptop was on when water was spilled onto it the backlight fuse may have blown on the motherboard.
You would need the schematics for the motherboard to know where it is, but usually is it a smd type fuse mounted on the motherboard close to the video cable connector.
完成的
添加一条评论
添加你的答案
derplife _yt 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 20
总计 653
