跳转到主内容
加入维修社区 - 创建账户
Repair information for the Asus VivoBook laptop series.
How do I replace a touchpad
Hello,
My ASUS VivoBook touchpad with numpad has gosttouch and doesnt work from time to time. I tried to sent it back to asus for repairs but it didn’t work, so now ik want to do it myself. Is it possible to repclace your touchpad or should i go to a professional?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi @lafracture,
What is the full model number of the laptop?
完成的
Hi @jayeff
VivoBook S14 K433JQ
Is this what you mean?
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @lafracture
Yes.
Knowing the model number means that you can source the correct replacement part(s).
Here’s a link to just one supplier of parts for your model.
From the parts list (click on the Touchpad category, left side), you can find out the possible cost of the part and also that the Asus part number for the Touchpad is 90NB0PZ4-R90021. (click on See details and then on Go to the product sheet in the Touchpad part entry box)
You can search online using this number only to find other suppliers that may suit you better. Don’t be surprised when you do this that the same Touchpad is being used in different models. As long as the part number matches it is OK.
I couldn’t find a keyboard replacement guide for your model (helps as the Touchpad is also located there) but found this video which shows how to open a Vivobook S14 series laptop and this video that shows what is involved with replacing a keyboard (which allows access to the Touchpad) in Asus Vivobook laptops in general.
Basically you have to nearly completely dis-assemble the laptop to do it.
Hopefully this will help you to decide whether to try it yourself or not.
这个答案有帮助吗?
得分 3
1条评论:
Not too difficult to get to battery, hard drive, or ram. Asus does have a service manual available which gives a few specifics such as how to remove or reinstall battery cable. They instruct near complete disassembly to approach touchpad, but loosening motherboard and output module allows keeping fan/heat sink and a difficult to reinsert display cable in place. Lifting motherboard slightly gets access to the one touchpad bolt underneath. This is not a machine designed for repair, and touchpad seems prone to failure.
完成的
添加一条评论
添加你的答案
Charlie De Breuck 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 99
总计 2,119
