跳转到主内容
加入维修社区 - 创建账户
iPhone 的首款型号,型号 A1203,提供 4、8 或 16 GB 容量,采用铝合金背壳。维修时需要进行大量的撬开操作,可能还需要用到焊接。此页面旨在帮助用户对 iPhone 2G 进行故障排除、维修及寻求帮助。
Broken Sim Reader Pins
Hello,
I always wanted a first generation iPhone and I bought a first generation IPhone to repair. I realized that my device is not reading SIM cards. Then I opened it and saw the broken pins. Can I just buy a broken motherboard and replace the sim slot? If not how could I fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I have replaced sim holders on a lot of iPhones but not this model. It looks easy enough. I am not sure how much heat you will need to melt the solder on these models, if you flow the joints with low melt solder you shouldn’t have a problem although you will probably need a hot air station as well as an iron.
The hardest part will be finding a non-working one to buy.
这个答案有帮助吗?
得分 2
1条评论:
Thank you so much?
由完成的 分享
添加一条评论
添加你的答案
Batu Köseoğlu 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 26
总计 393
