跳转到主内容
加入维修社区 - 创建账户
Razer Blade Stealth 是 Razer 推出的高端超极本系列。最新型号为 Razer Blade Stealth (2019)。
Blue screen after battery replacement?
I replaced the battery in my Razer Blade Stealth 13” (2017). The laptop indicated that the battery was installed and charged to 100%. But the laptop would crash and blue screen after a few minutes of using it, which it does not do with the battery not installed and has never done previously. Is this a hardware malfunction, or a bad installation job?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
I replaced an HP battery and the laptop/notebook does the same thing. After being on a few minutes it just shuts off. No error messages. Just off. It stays on if I unhook the battery. I’m attempting to calibrate the battery.
由完成的
添加一条评论
1个答案
It very well could be a defective battery. What I would do is this, if you have the old battery try re-installing it temporarily and see if that resolves the issue. If it does, then definitely a bad battery. If it doesn’t then it must be something else.
What is the error you get when the laptop crashes?
这个答案有帮助吗?
得分 0
1条评论:
I don't get an error code when the laptop crashes; it just says "An error has occurred and we are getting more information" or something like that, then the laptop restarts almost immediately and gets stuck in the "Aptio Setup Utility" menu until I pull out the battery. Unfortunately I no longer have the old battery because it was bloated.
由完成的
添加一条评论
添加你的答案
Jake Wilson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 32
总计 1,167
