跳转到主内容
加入维修社区 - 创建账户
The B6 and B7 versions of the Volkswagen Passat are front-engine large family cars produced by Volkswagen, a German automaker. The B6 line of the Passat was produced between 2005 and 2010, and the B7 line was produced between 2010 and 2015 as a facelift of the B6 line.
Radiator Fans Run Continuously
2014 VW Passat SE, 1.8L Turbo Gas Engine. Recently changed radiator and turbo cooler, along with A/C condenser. Then changed radiator fans (both - entire assembly). Now fans won’t shut off. Have been told may be ambient sensor, but cannot locate. Cannot locate control module, etc. No codes in ECM. Help please!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I had my cooling fans running at max on my vehicle (and always showed cold engine), and it turned out to be the engine temp sensor went bad.
On eAutoRepair.net you can subscribe to access the full repair/service manual for your vehicle. It should help to locate the components in the vehicle.
这个答案有帮助吗?
得分 0
1条评论:
Thank you!! I’ll definitely check out that website!
完成的
添加一条评论
添加你的答案
Robert Mayo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 33
总计 2,090
