跳转到主内容
Repair guides and support for your Philips TV.
210 个问题 查看全部
The screen has a blue tint to it and no color adjustments.
Philips TV Model 55PFL5402/F7 . Reset to factory settings no help. Unable to change color with Blue, red or green on screen controls. What is the TVs problem??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
My aunt's 55” Phillips looks exactly like the image above. I tried all of the different picture mode settings and firmware update, but the only adjustment that made any difference was to turn the blue saturation as low as it could go. Now it's a bit too red and we're off to buy a new TV.
This was one of those 2018 *Black Friday* Walmart deals with a too good to be true price.
完成的
Same things has happened to ours, also a Black Friday deal a few years ago. :/
完成的
添加一条评论
2个答案
最有帮助的答案
Jeff possibly the backlight strips. All LED’s start out as Blue and are then coated. If that coating fails you get more blue/purple hue. Post an image of what your screen looks like so we can see what you see. 在已经存在的问题里加入图片
You would have to replace the backlight strips to remedy the blue.
这个答案有帮助吗?
得分 1
2条评论:
Posted the TV image. Thanks for response
完成的
Now that is blue. this is more than just a blue hue from bad backlights. Dang, it's blue:-) Anyhow this is a case where I would at minimum switch out the T-con board and see if that corrects it. Of course, you did set your menu properly and made sure your adjustments are okay.
完成的
添加一条评论
try auto picture that,s how i got rid of the blue color but only 2 setting,s have no blue color but it work,s
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeff 将永远感激不已
浏览统计数据:
过去 24 小时: 12
过去 7 天: 102
过去 30 天: 444
总计 17,758
