跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
Magsafe Board changed...No power!
I'have changed the Magsafe board. Magsafe LED is green,
But no power
Reset SMC
connector keyboard ok
It's a MacBook 2009 white. I think that the keyboard does not function, and i dont find power connector on the logic board.
thank you for your help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Please give us the last 3 characters of your serial number so we can verify your exact machine.
完成的
It' a early 2009 the Keyboard was changed and the serial is on the Keyboard
完成的
添加一条评论
1个答案
最有帮助的答案
Check the voltages at the battery connector using a multimeter or similar. The two outer pins are ground. The three inner ones should read something around 3,5 V. If the machine suffered a spillage have a hard look at the Magsafe -> board connector and also at the Board -> battery connector.
这个答案有帮助吗?
得分 3
1条评论:
The 16.5 VDC, pinout is on the right side of this link: http://en.wikipedia.org/wiki/MagSafe
完成的
添加一条评论
添加你的答案
Mikhrych 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 439
