跳转到主内容
加入维修社区 - 创建账户
重新设计的 Pathfinder 于 2012 年 10 月下旬作为 2013 款车型上市。正如第二代 Pathfinder 一样,它再次放弃了基于卡车的非承载式中框结构,转而采用了一体成型机身设计。
2014 Pathfinder Transmission issues
My dad’s 2014 Nissan Pathfinder recently started having what we beleive are transmission issues. as we attempt to accelerate it feels like the transmission is “slipping”, or put differently the car starts to shake a bit and it feels like power is not being applied to the wheels. we think its transmission related because when we put it in D or R it takes a moment and the car is almost like it’s in neutral before power is applied to the wheels. it takes 3-4 seconds now for the power to get applied, and then it feels like its “slipping” . i dont know if my description of the problem helps but its the best i can do. my dad said he reseached some info online and apparently this is a problem that nissan knows about but is not doing anything about to fix. he mentioned it might be a software related issue and had mentioned that some people had the problem fixed when a combination ofa valve was replaced with a software update. he said he already had the value in question replaced a while ago so im not sure what to do here. hes going to take it in but i'd love to be able to offer some helpful info as i fear this issue is going to be expensive. thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
I have had issues with vehicles not shifting/accelerating properly when fluid levels were low. It is a very basic question I know but have you checked fluid level for the trans?
完成的
添加一条评论
2个答案
已选择的解决方案
It is because of the solenoid failure. Need to replace the valve body and reprogram the transmission
这个答案有帮助吗?
得分 2
添加一条评论
I also had this problem on my 2014 and my 2015 pathfinder it’s the Nissan cut they aren’t the best I just replaced the transmission but replacing the transmission is professional level as you have to drop the whole front subframe (engine, transmission, ect.)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
ryandasilva23 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 74
总计 3,043
