跳转到主内容
The Kenwood Chef A701A is a stand food mixer released by Kenwood.
47 个问题 查看全部
gear oil seems dry because it smells burnt can I oil it?
My old mixer gear oil seems dry because it smells burnt can I oil it?
Which oil is recommended
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Onyeakpo Chinedu  you did not tell us what make and model your mixer is. If it is a Kenwood Chef then there is no oil in the gearbox. It uses grease in the gearbox. Yes, you can replace that and since it is a sealed box you do not need to use food grade grease but can go to regular white lithium grease or even more expensive Moly grease. Just remove the old grease and clean the gearbox properly. Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Onyeakpo Chinedu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 266
