跳转到主内容
加入维修社区 - 创建账户
Chrysler PT Cruiser 是一款由克莱斯勒设计并向全球市场销售的小型家用轿车/紧凑型 MPV,采用前置前驱布局。该车型提供 5 门掀背版(2000–2010 年)和 2 门敞篷版(2005–2008 年)两种车身样式。
Pt cruiser limp mode
Where should I begin to look for the cause?
This is really strange , my car shifts gears fine until I hit a good bump along the street. Once it hits a couple manhole covers or potholes the dash display flickers once or twice and the transmission stops shifting past second gear. I do not believe this is a mechanical problem because it always seems to happen when there's a few bumps or potholes? Has anyone had this problem and how did you find the issue? Where should I look,it strikes me as an electrical problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Hi,
Get the OBDII port scanned for any fault codes.
This may be a good place to start to find out what is happening when the car is in limp mode.
I've read that some auto parts retail chains in the USA will do this for free
完成的
添加一条评论
4个答案
最有帮助的答案
as previously mentioned in a comment, get the codes read. In the USA places like autozone and O'Reilly will do this for free. See what it says. The fact that a bump causes it tells me its almost certainly electrical. Loose grounds or plugs are likely culprits. Its going to suck, but you'll need to start chasing wires and double checking everything until you find the cause. Could be electrical connector to the transmission.
这个答案有帮助吗?
得分 2
添加一条评论
It is an electrical problem, it starts from the connection that reaches the transmission and sees separating the cables, it is probable that some have been damaged and they are making a short, it already happened to me and I solved it that way, with patience separate and if there are stuck cables, peel them off and tape them
这个答案有帮助吗?
得分 1
添加一条评论
Check the electrical connectors at the pcm and Tom under the hood
这个答案有帮助吗?
得分 1
添加一条评论
I too have a 2002 cruiser. My transmission stopped shifting gears out of no where . I was stuck of stupid until someone suggested that i change my transmission filter (never even heard of it,but yes it has one) once i changed it and the fluid itself. I have not had that problem since
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Margaret Groot-Koerkamp 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 25
总计 2,017
