跳转到主内容
Repair guides and support for your Samsung TV.
2614 个问题 查看全部
Samsung TV model UN49KU7000FXZA. HELP
Samsung TV model un49ku7000fxza. They didn't have my tv on the list on this site so I wrote it in.
Left side flashing white and the rest of the screen is black and unresponsive to anything I try. The red light won't turn on, remote won't work with the tv at all. No damage as far as I know. Gaming uses mostly. Was ok last night when I was on, but when I woke up it was “off” and doing the left side flashing thing.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
This will be a problem with the LCD panel or the connections to the edge of the glass. There’s a faint chance you might be able to insert some sort of packing to press those connections onto the glass (essentially, they’re attached with a kind of conductive adhesive) but it is only a very long shot I’m afraid. A replacement LCD panel, even if you could get it, would probably cost as much as a new TV.
这个答案有帮助吗?
得分 1
添加一条评论
@hunt3r0b disconnect the main board from the power board. See if that stops the blinking and if all of your back lights come on (which should). You can see the backlights through to holes in the back of the panel. This could be an issue with the power board (since you said the red light would not come on) it is also possibly a T-con error or, like was mentioned already, a bad panel. Post a couple of good pictures of all of your boards with your question. That way we can see what you see.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
I have the same model of Samsung TV with the same issue that you described. I’ve exchanged the motherboard and power supply for the ones I got online, but the problem persists. My last option is to follow the solution Philip introduced to you. Did his method resolve the issue?
Update (01/09/2022)
UPDATE:
I owned the same model and had the same problem. And I fixed it by replacing the LED Backlight Strips. You should try it if you haven’t thrown out yours.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hunter Barney 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 8
总计 203
