跳转到主内容
加入维修社区 - 创建账户
2019 年 3 月发布,型号为 SM-A305FZRFINS
Vibration is not working
vibration on my phone isn't working.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
May phone samsung galaxy a30 not working vibrate please 😢 halp
由完成的
How can i fix step by step
由完成的
添加一条评论
1个答案
最有帮助的答案
Hi,
Have you checked the vibration settings in Settings > Sounds and Vibration > Vibrate while ringing and also Vibration intensity and Vibration pattern, you didn’t say?
If they’re all OK try wiping the cache partition and check, in case it is corrupted cache data that is affecting the vibrate somehow.
If still no good try starting the phone in safe mode and check.
If it works OK in safe mode then a downloaded app is the cause of the problem. The tricky part is to find out which one is the culprit. You will need to uninstall each downloaded app, one by one and test the phone in normal mode between each uninstall to see if it works OK. When it does then the last downloaded app that was uninstalled was the cause of the problem. A downloaded app is one that you downloaded and installed in the phone and was not pre-installed on the phone when you first got it.
If still no good, perhaps the vibration motor is loose or faulty.
Here’s an image taken from a teardown video for the phone showing the location of the vibration motor, that may help, (supplier example only to show part and what it may cost).
(click on image to enlarge for better viewing)
If the vibrate motor is faulty there are other suppliers online that may suit you better. Just search for Galaxy A30 vibration motor to get results
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
TAHIR Alomari 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 1,661
