跳转到主内容
加入维修社区 - 创建账户
2018 年 9 月 21 日发布。型号 A1920、A2097、A2098、A2100。提供 GSM 或 CDMA / eSIM 或 nano-SIM / 64、256 或 512 GB / 银色、金色或深空灰色版本。(读作“iPhone 10 S”。)
Not responding to touch after screen replacement
I replaced an iPhone XS screen because it was cracked and it was ghost touching. Also replaced the battery because it wasn’t charging. The phone charges now so the battery replacement seems to be a success, but I’m having issues with the display. It turns on fine and the picture looks fine but it doesn’t respond to touch whatsoever. I have checked the connection multiple times and they all are connected properly but nothing I do is working. I have tried force resetting as well and they didn’t do anything.
I’ve replaced iPhone screens before (including an IPhone XS) but I’m still an amateur so I have no idea what else could possibly be wrong with it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Thanks for your answers! I emailed the company and they said they’d replace it. I’ll update if the new one works
由完成的
This happened to me today. Replaced an iPhone XS with a new screen from iFixit. Apple told me to do a hard reset. That fixed the problem. I think this is common and hopefully iFixit will update their repair instructions.
由完成的
添加一条评论
2个答案
已选择的解决方案
You will need to rule out the screen as it may be faulty. If the screen is not the problem it will be a logic board problem.
 The touch power and data lines are on the bottom layer of the board and are connected to the top half of the board through solder balls. If the phone has been dropped in the past it could have caused one or more solder balls to crack.
To diagnose your problem once you have determined it’s not the screen would be to take measurements of the connector pins with a multimeter and check against the board view schematics.
这个答案有帮助吗?
得分 1
1条评论:
thisneeds pix
由完成的
添加一条评论
Brianna.
There is good chance that the screen is broken or in general is cheap.
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Brianna Valenzuela 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 33
总计 3,113
