跳转到主内容
加入维修社区 - 创建账户
本指南旨在通过提供维护、升级和故障排除方面的必要信息,帮助 HP ProBook 650 G2 用户充分发挥其设备效能。无论你是想要更换组件、排查性能问题,还是仅仅想更好地了解笔记本电脑的规格,本指南都提供了详细的说明和实用的资源。本指南重点介绍了 ProBook 650 G2 的核心功能,包括可升级的内存和存储,并为常见维修提供分步支持。通过使用本指南,用户可以延长设备的使用寿命,并确保其在商业环境中持续可靠地运行。
Replace PowerJack for AC/DC Adapter
How difficult is it to repair power jack on Probook HP 650 g2 laptop
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi @bully357 ,
You would need soldering tools and skills to replace the power jack (supplier example only) in your model laptop.
It also involves dis-assembling the laptop to remove the systemboard so this can be done.
Here’s a video that shows what’s involved. The actual DC power socket replacement is seen from ~26:30 minutes onwards into the video.
Here’s the maintenance and service guide for the laptop, which may also help. Go to p.60 to view the necessary pre-requisite steps and then the procedure to remove the systemboard
这个答案有帮助吗?
得分 1
添加一条评论
Hello Jason Bolstad! Power jack replacements on these types of laptops can range from very easy to do to very difficult. However, on your particular laptop, it would seem as if the charging port is directly soldered onto the motherboard instead of connected to it through a cable. The latter would be much easier to replace as it would only require you to open up the computer, unplug the faulty charging port, and replace it with a new one. However, as all of the ports of your laptop are on one side of it, this indicates that the charging port is directly soldered to the motherboard. I have confirmed this through some research on your laptop’s motherboard. This would mean to replace the charging port, you would need to open up the computer, take out the motherboard, desolder the broken charging port, and solder on a new one. This can be very difficult to do for a person who has never heard of or touched a soldering iron before, but if you would like to try it, you can consult some people on iFixit that have experience with this type of repair. One thing that you could do to try to test if the charging port is indeed the problem is to buy a replacement power cord for your laptop as that could be the issue instead. I hope this has helped to fix any problems that you have had and resolved any issues with your device.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jason Bolstad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 23
总计 1,279
