跳转到主内容
加入维修社区 - 创建账户
LG V40 ThinQ Android 智能手机于 2018 年 10 月发布。V40 是 LG 首款配备五颗摄像头的智能手机。
Does a replacement screen always include glass?
My LG V40 ThinQ has red burn in, and I was wondering if replacement screens always come with the Gorilla Glass, or is the OLED screen a separate item underneath? The outer glass is good so I'd rather avoid replacing that if possible. Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The replacement always depends on the level of damage and the type of display your device has. Irrespective of damage the device having an LED display need to change the glass only. But, in case of AMOLED to Super AMOLED you are required to change the glass and screen both.
Explanation:
LED screen has a display glass on the top that displays the UI and beneath that screen, there is a tube-like LED light that provides the light to make the UI visible. So, in case of minor damage you are just required to change the upper display screen and not the LED screen beneath it. While on an AMOLED to Super AMOLED there is no backlight thing. They have tiny led bulbs integrated to display the color information as per UI. So if you damage your AMOLED to Super AMOLED, you are required to change the glass and display both as they are combined.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gary Benites 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 16
总计 262
