跳转到主内容
加入维修社区 - 创建账户
Released in 2017, the JBL E45BT are wireless on-ear headphones with Bluetooth 4.0 and 40 mm drivers, rated for 16 hours of battery life.
Left side doesn't work when using the wire, how do I fix it?
A while ago the wire got caught and was yanked out when using the headphones. When using bluetooth both sides work fine, but when using the wire, only the right side where its connected to works. However, I can get the left side to work by pushing on the connection between the wire and the headphones.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@ronnchao sounds like either a loose solder connection or partially broken wire. To inspect and repair that you will have to open up the left side. Remove the outer ring (it is glued on, so some heat from a hair dryer etc. and a plastic prying tool will help with that). Once the outer ring is removed you should see four small phillips head screws. Remove those and you should now get to the wiring etc. Of course if you are stuck with anything or need some more help, post some good pictures of what you see with your QUESTION. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Ronald Chao 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 127
