跳转到主内容
加入维修社区 - 创建账户
Nest 第三代智能温控器。发布于 2015 年 9 月 1 日。型号:T3007EF、T3007ES、T3008US、T3010FD、T3010GB、T3016US、T3017US、T3018US、T3019US、T3021US、T3032US。
How to drain battery
The iFixit instructions with the replacement battery says to charge, drain, and charge. Does anyone know how to drain the battery in a consistent way and how long does it take to do so. Obviously, reconnecting the thermostat back to the base won’t work since it can charge from the base.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @sscollis ,
Try disconnecting the power from the base.
As to how long it takes would depend on how much charge the battery has and what the load current is. I don’t know the answer to this.
这个答案有帮助吗?
得分 1
2条评论:
If you disconnect the "C" wire (probably blue) it will probably drain. Might take several days and inevitably will die at 2 am when it's 95 degrees out and you will wake up in a hot sweat! Personally I think that whole "memory" thing with batteries is left over from old NiCAD batteries and likely unnecessary for this application.
由完成的
@nicksartor Nowadays the charge/drain instructions are not for the benefit of the battery "memory", but rather for the sake of battery health calibration to establish a full/empty baseline for monitoring the battery charge.
由完成的
添加一条评论
添加你的答案
Sam Collis 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 38
总计 962
