跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
MBP Display not working, Backlight and computer functions normally
Greetings! I have read through other threads but none of those solutions worked
I replaced the speakers on my MBP and there was no issue, but revently, my display went black and does not work. I tried all the software checks, tried disconnecting and reconnecting the display cable, but nothing. It works fine on an external monitor, and the backlight responds as well.
Additionally, I replaced the LVDS cable, but still the same issue. All of the connectors look okay on the logic board as well, as far as I can see. This is getting super frustrating, since I feel Ive tried everything at this point. Any ideas? Thanks so much!
Edit 1:
Edit 2:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
9条评论
Using a flashlight shine it through your lids logo to be doubly sure your backlight is not the issue. Do you see the faint image of your desktop and the icons on it?
Sometimes the backlight will fire up doing the boot up process and then go out. We need to know if that is the case here.
完成的
Hey Dan!
Shining a light doesnt show any faint image.
完成的
@lemellekh2 post some good pictures of your logic board and the connector area. Let's see if you may have popped off a component etc, while replacing the speaker 在已经存在的问题里加入图片
完成的
@oldturkey03 Thanks so much for reaching out! I added some pics.
完成的
@lemellekh2 if you can post another one from the other side of the connector. Lets see if you can get close to the solder points.
完成的
显示更多的4条评论
添加一条评论
2个答案
已选择的解决方案
@danj @oldturkey03 Sorry for not getting back! Turns out it wasnt a display assemblyissue, but a small component on the logic board snapped! I got it re-soldered and got some mroe life out of it!
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Time for a new display assembly then! 2015年中视网膜屏macbook pro显示器组件更换
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alain Sullivan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 131
