跳转到主内容
The Shark Rotator NV502 vacuum was made in 2013, weighs 15.5 pounds, and includes a lift away handle. The vacuum can be used on both carpet and hardwood floors.
My shark powered lift away won’t turn on
When I turn on my shark lift away, the lights will come on but the vacuum doesn’t do anything. It doesn’t make any noise, the brush doesn’t move but the lights do come on very bright. Any suggestions of what could be wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
@skelly64 use something like this video to work on your vacuum. Since your lights are bright, and you seem to think brighter than usual, I would suggest that you use a multimeter and check if there is actually power going to the motor. Once you have your vacuum partially disassembled it might help you out if you post pictures so we can continue to guide you 在已经存在的问题里加入图片 All you should need for this check would be your basic hand tools (screwdrivers etc.) and a run of the mill multimeter. Nothing fancy.
这个答案有帮助吗?
得分 1
添加一条评论
motor bad, brushes jammed causing the overload to trip, or an interlock switch open because it is bad or the parts are not assembled correctly.
这个答案有帮助吗?
得分 0
添加一条评论
My Shark Navigator Lift Away will power up when I tilt the handle in usage position. The beater works too. However, it goes off when I switch to the bare floor position with the switch.
Any ideas?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sandy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 88
总计 2,819
