跳转到主内容
Repair guides and support for computer monitors produced by Samsung.
88 个问题 查看全部
Samsung SMT 3232a HDMI not working
Hi need some help / advice please, my Samsung SMT 3232a kept turning off and on, was told it was a main board issue so changed that for a spare bought from internet, now it stays on but the HDMI port will not recognise and I can’t find another part on the internet. Looking for some help, please. Is there anything I can do with the now two faulty boards to make a good one such as swap the ports or is it likely to be something else. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Carl Burton it could be the HDMI port itself (maybe shortened out or bend/broken pins) but it also possible that this is your HDMI IC on the board itself. Sometimes a simple reflow of it can fix the issue at least temporarily. Post some good pictures of both boards (old and new, both sides) with your QUESTION. That way we can see what you see. 在已经存在的问题里加入图片
The turning off on the first board could actually be related to some bad capacitors. Samsung monitors had some issues with a bad batch of caps…..
这个答案有帮助吗?
得分 2
8条评论:
Update - The PC port doesn’t work either, is this likely to be the board itself or would there be any further reasons that ports don’t work that I could try?
完成的
It sounds like your input ports are failing (most likely due to a failing processor). That would usually be an issue with the main board.
完成的
Ok so I’ve managed to check again and all other inputs do work, I think the port is the problem although it doesn’t display on screen if I plug my phone in my phone does recognise the input as comes up saying connected on phone? I guess a new board would be the answer but I can’t locate another any recommendations please? MAIN AV BOARD BN41-02365A (BN91-14862N) - SAMSUNG SMT-3232A
完成的
@Carl Burton
Here is a supplier.
There may be others. Just search for BN41-02365A (BN91-14862N)
完成的
This is the part and person I bought from but unfortunately the HDMI didn’t work, I’ve searched but no real joy, was looking for some sort of inspiration
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Carl Burton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 57
