跳转到主内容
Low temp power error after replacing charging port and wireless pad
Note 10+ had a low power warning. I replaced the charging port and the wireless charging pad, but the error is still there. I confirmed the temp sensor is there and all connections look fine. Any idea what else I can do? Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Peter Rizzuto you want to check one of the common errors on this. It could be caused by a resistor on the NFC Flex. See what needs to be checked to determine that this is/is not the problem on this site https://www.microsoldering.com/samsung-g...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Peter Rizzuto 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 36
