跳转到主内容
三星新旗舰的大号版本,盖乐世S8+。发布于2017年4月。
How to read memory externally?
There was damage to the phone that wasn't able to be repaired, so in an attempt to save the photos / saved data, I took the phone apart. I was wondering if there is a way to read the on-board storage externally, independent of the phone. I believe the piece I would like to read is the Toshiba THGAF4G9N4LBAIR 64 GB UFS, which is the nand flash.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Onify sorry but it is not possible without repairing the phone so that it at least boots etc. There is no other way to recover data from your S8. On older models you could desolder the UFS memory chip (chip-off) and then read it in external reader, but now even this dump will be encrypted with no chance to ever decrypt it. Consider your data lost.
这个答案有帮助吗?
得分 1
1条评论:
Hypothetically if I attached the device to an external board running in mock s8 environment could I pull this off if I know the password /code ? My wife was a fool when it comes to data, loves pictures, lost pictures, and doubts my abilities so I have something to prove. I feel like I wire the ssd to a pi that is running the Android os I could get the system to act like it was the phone. My work on android systems is nada so maybe you can tell me more about why this won’t work.
完成的
添加一条评论
someone may be able to do that, but it will cost MUCH more than doing a backup.
这个答案有帮助吗?
得分 0
1条评论:
Unfortunately a backup cannot be done since the phone will not power on or charge.
完成的
添加一条评论
添加你的答案
Onify 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 646
