Where is the reset button on the dsc w55
where is the reset button
I believe that this camera does not have reset button. You can reset the Camera by either using the Initialize option from the Menu or removing the battery. The Initialize option is under the Setup Menu of the Camera. To reset the Camera, remove the battery, press and hold the power button for more than 15 seconds and then reinsert the battery. Hope this helps, good luck.
这个答案有帮助吗?
Did not work.
What did not work? What are you trying to accomplish? What is wrong with your camera? You need to give a bit more info :)
Well, Ithink there is a reset button. You can find it opening the battery & card lid. There is a tiny hole, you should press it about 3 seconds.
这个答案有帮助吗?
go to any photo => click on "menu" button => setup=> internal memory tool => format=> OK :) that's all.
这个答案有帮助吗?
Yuen on your Camera and press menu go to setup and go to setup 1 and press initialize!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 38
总计 13,203
2条评论
Sony Cyber-shot DSC-W55 LCD Screen SHOWING BLACK, ITS FLASH IS NOT WORKING
PLEASE HELP ME.
由 sshankar789 完成的
Show reset button on youtube video for my cybershot digital camera
由 nagender.gunampalli 完成的
