跳转到主内容
加入维修社区 - 创建账户
Not charging, no flashing light
My device is not the first Wonderboom but the second, Wonderboom 2, could not find it as an device on here. When I try to turn it on it flashes red and makes the power down sound. When I connect it to charge nothing happens, no lights turning on, nothing. I’ve tried resetting it by holding down all the buttons but that did not work.
I have contacted the support multiple times but I’m not even getting an answer from them even though I am covered by the warranty.
So I would like to fix it myself instead. Anyone know how?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
First are you sure your charger and the cable are working? I would get a USB power meter to see if there is power even getting to the speaker. If it is then you really need to get yours replaced under warranty as these speakers are too well sealed up to open and then what then? Replace the battery is about all you can do. Otherwise try a different charger and cable.
Try emailing UE email support
USB Mini Voltmeter to test chargers and charging functionality.图片
产品
USB Mini Voltmeter
$9.99
这个答案有帮助吗?
得分 1
2条评论:
Yes, charger and cable are both working. Have checked with other devices. Saw a youtube video of a guy removing an capacitor on the first wonderboom so I was thinking maybe there is a similar workaround on the wonderboom 2
由完成的
Often the socket or charging logic within the unit dies. Once you open it its not water tight! If under warranty I would push for free Vs getting nothing but mess or half useful speaker.
由完成的
添加一条评论
I had the same problem!I!!!! I changed chargers & the cord tested it(the set+up) & charges away. The light Didn't come on but the unit charges. Kris. Aloha
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Comrade_Gorbachev 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 65
总计 5,721
