跳转到主内容
加入维修社区 - 创建账户
13.3 英寸翻转式触摸屏笔记本电脑 (SVF13NA1UL)。
Can I replace the motherboard?
Hi,
I have two Sony Vaio motherboards. The first one is:
From this laptop's model SVF13n12SGS.
Motherboard P/N: 31FI1MB0000
S/N: A1974482A.
The second, from this model: SVF13NA1UM.
Motherboard P/N: 31FI1MB00B0
S/N: A1974483A.
The first motherboard (A1974482A) is not working. Thus, can I replace the first one by the second one?
(I do not want to buy a new motherboard)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
7
If they're both the exact same model, then yes, very likely.
If they're different models, but from the same series, then it might be doable, but depends on the exact models.
完成的
@jgraham1976
Do you mean the motherboard P/N: 31FI1MB0000
S/N: A1974482A
Must be replaced by a motherboard with same numbers?
完成的
It would help, but if they are not the same then you may have to adjust some of the drivers. But it is doable.
完成的
Is there any other issue except the drivers?
完成的
添加一条评论
1个答案
If one motherboard is not working and you have the second one that is working but the problem in replacing is the accepting of a second motherboard that I think only can be done if both motherboards is same otherwise you will have problems like over heating or hanging some times.
So before replacing you should have a system integration plan for it so it can be done perfectly
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
shdotcom 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 21
总计 526
