跳转到主内容
加入维修社区 - 创建账户
三星的旗舰手机,配备手写笔,是 Note8 的继任者,于 2018 年 8 月发布。具有 6.4 英寸显示屏和最高 512 GB 的内置存储空间。
Cellular Antenna Issues Galaxy Note 9
I dropped my Samsung Galaxy Note 9 last October, cracking the screen and display assembly. I replaced the display assembly myself (and replaced the charging port), but ever since have been getting a weaker than normal cell signal. It is typically one or two bars less than my brothers device at any given location. This issue leads to dropped/ unstable calls, failure to send texts, etc. GPS antenna also seams to go offline more frequently. I’ve tried all the software fixes, and am convinced it is hardware related. Where are the antenna locations on the phone? Are they replaceable or modifiable?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
I would replace the charge port and the small coaxial antennas that attach to the charge port. Just make sure you order the right variants according to your model number. I’ve seen customers and other repair shops replace their ports with the wrong variant resulting in cellular issues although the most common symptom was it would say “No SIM”.
这个答案有帮助吗?
得分 1
添加一条评论
For modern phones, the antennas could be all over the edges of the phone, and multiple antennas are required to ensure proper cellular reception and throughput, so if you have to fix them, fix all of them.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Evan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 32
总计 2,032
