跳转到主内容
加入维修社区 - 创建账户
Dell 于 2011 年至 2012 年间发售的商务笔记本电脑。这些笔记本电脑通常预装 Intel Core i5 处理器和 Windows 7 专业版操作系统。
Why my screen is black?
Hello!
I’ve got an old Dell E6420 and the screen is not working. It is black and showing an image only when I place a light near it.
Is it possible that this flex is causing the issue?
The display itself looks ok. I’ve got no tools or knwoledge to go further in my tray to fix it.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi,
It seems as though there is a backlight problem but whether this is in the LCD panel, the video cable or cable connector at either end (loose?) or the motherboard would have to be determined first.
Looking at the image you posted it may be not where you indicated but perhaps the wires that are connected to those pins. The last wire looks as though it is broken but it may just be the picture. Also unless what you have shown are pins 38 & 39 it doesn’t apply to the backlights. The pin numbering should be printed on the motherboard. 1 at one end and 40 at the other end of the connector on the board
(click on image to enlarge for better viewing)
Without tools or knowledge this will be more difficult for you to do yourself.
Here’s an image taken from p.24 of the schematics for the laptop’s motherboard, showing how the backlight power is connected to pins 38 & 39 on the video cable connector.
With the laptop turned on the power is always there. The backlights are turned on and off in the LCD display panel by a signal voltage being present or not on pin 9. (disp on).
(click on image to enlarge for better viewing).
If the power is not there then there is a problem on the motherboard with the backlight power supply circuit.
If the power is there, turn off the laptop and then gain access to the LCD panel so that you can disconnect the video cable from the panel (and the motherboard) and use an Ohmmeter to check for continuity of the cable’s backlight power wires and the Display On wire from end to end.
Here’s the service manual. Go to p.103 to view the necessary pre-requisite steps and then the procedure to remove the display assembly.
If the cable is OK then the problem is in the LCD panel.
It may be easier to source a replacement panel than to replace the LEDs. Usually the part number can be found printed on the back of the panel somewhere. Search online using the part number only to find suppliers.
If doing all this seems too daunting, contact a reputable, professional laptop repair service and ask for a quote.
这个答案有帮助吗?
得分 2
添加一条评论
The black screen issue would be the monitor backlighting died.
You can check up YouTube on how to repair led backlight (basily u dissasemle whole lcd panel, replace white led strips and put it back together)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
pablobalbin 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 13
总计 1,221
