跳转到主内容
加入维修社区 - 创建账户
PlayStation 3 Slim是PS3的第二个迭代机型,机器型号CECH-2000。索尼电脑娱乐推出此机型来修复初代“胖机”PS3的诸多硬件问题,于2009年9月1日发布。
change the power supply for ps3 slim from 220v to 110v
hi
I'm abdulaziz
I have a real problem with my ps3 slim
the problem is : my ps3 work in 220v and I in the U.S and U.S only have 110v so my ps3 wont work only if I use a converter . the converter overheat every hour and turn off automatically and after on hour later it work again . I tried to buy another converter but all of them the same (will turn off) I play ps3 more than 6 hour a day and these converter want me get killed by not working ...
can you please tell me if I can buy a 110v power supply and change my 220v power supply and where I can get it plz .. and if I can't can you tell me about a converter that work more than 5 hours or any good converter beside the one I have ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
+ For your feedback to help others.
完成的
添加一条评论
2个答案
最有帮助的答案
abdulaziz,you should not have to use a transformer at all. the power supply in the PS3 Slim have universal power supply to be able to operate 100-240V 50/60Hz. All you may need is a power cord from the power supply to the electrical outlet.
这个答案有帮助吗?
得分 3
13条评论:
mine is not 110v
it only handle 220v . I had read the back of PS3
it say that it only will work with 220v
i tried 110v but it didn't work
完成的
Have you actually taken a look at the inside on your power supply? Just make sure, it is not uncommon to have it labelled on the outside for the origin country. I have not heard of Sony using separate power supplies for different countries, but anything is possible. Anyway, instead of buying a transformer, get a power supply for the 110V they are easily available and not a bad price http://www.thegamersfix.com/product.php?... Are you sure yours won't work on 110???:-)
完成的
yes I'm Sure ... Thank you bro
can you tell me how i can change the power supply by video or images plz?
完成的
there is a good guide here PS3 Slim版电源模块更换 are you sure your power supply is not a dual power supply? I would hate for you to have to change it...;-)
完成的
what is the "dual power supply" ? can you tell me please ?
how can I know if my ps3 dual ?
do you want me to take a picture of my PS3 slim and up upload it here ?
完成的
显示更多的8条评论
添加一条评论
I just plugged mine in after shipping our stuff from the UK to Canada and it works.
The label says 220-240v and it just works.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
abdulaziz 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 27
总计 14,377
