跳转到主内容
加入维修社区 - 创建账户
Apple 在 2020 年十月更新了 iPad Air 平板电脑,其采用 A14 Boinic 处理器,10.9英寸屏幕,全新外观设计,以及内置在按键中的触控ID。
Touch ID Button Replacement
Dropped my iPad Air 4the Gen square on the Touch ID button and it will not recognize fingerprints any longer. Not finding a replacement part for this item. How can I get this fixed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
I am having issues actually finding a replacement button. The button itself is cracked and piece broke off. Any suggestions there?
May just have to bit the bullet and take it to apple.
由完成的 分享
You can find these on ebay
由完成的 分享
添加一条评论
5个答案
最有帮助的答案
Touch ID is one of the hardest things to restore. I am not sure about iPads but there are programming tools such as the JCID that can copy the codes that pair your button to the logic board, then write them to a new home button. This should do the trick in getting a replacement home button’s full functionality back.
Most components in apple products are paired with the logic board and either stop working or disable features after the pair component is changed. Again there are programming tools, I use the JC V1S myself on iPhone repairs, but I have not looked into iPad programmers.
Hope this helps :)
这个答案有帮助吗?
得分 2
6条评论:
Almost! The original button needs to be readable! Often they aren't after being damaged.
Best to take it to an Apple Store and let them fix it as they have the magic tools to do it.
由完成的 分享
Fixed many a home button, even cracked ones, if the flex is good and the damage is to the outer layers there's a high chance of it working. Plus who doesn't want a JCID device to play with XD
由完成的 分享
@eazy_pc_repairs - What can I say you have the skills! ;-} Most DIY don't ;-{
由完成的 分享
@danj It honestly, for some weird reason, never crossed my mind that a high percentage of posters are not professionals who do this day in, day out :)
由完成的 分享
I have the same problem! But I don't need Touch ID at all, it's just that the button warms up very much, despite the fact that I disabled Touch ID! Is it possible to programmatically disable the Touch ID function completely or physically disable it, but to make the power button work? @eazy_pc_repairs
由完成的 分享
显示更多的1条评论
添加一条评论
Took my iPad Air 4th gen in today to a repair store. My problems were bent frame resembling a ~ , cracked glass, lcd was OK, power/Touch ID sensor was cracked and broken as well as getting extremely hot to the touch. All said and done I was quoted $125. This is to replace the power/Touch ID sensor unbend the frame and apply a clear zag protective restorative film to mend the cracked glass as well as re-seat and re glue and make it resistant to further damage. All in all not bad imo. Thanks for reading.
这个答案有帮助吗?
得分 1
添加一条评论
Unfortunately Touch ID is paired to the iPad Air like with most apple devices unfortunately even if you were to replace Touch ID button yourself it still wouldn’t work because it wouldn’t be paired the only way to do this is with special tools only apple authorized repair centers have
这个答案有帮助吗?
得分 0
3条评论:
@nicholaswiding Hi, Touch ID itself I don't need it, I just wanted you to cut it down completely, because the button warms up a lot. Can I turn off the Touch ID ribbon cable to make the power button work? What do you think? Thanks
由完成的 分享
I have the same ıssue. My Touch ID doesent work and button warms up a lot :/ I wouldnt buy apple after that
由完成的 分享
@amur221 Did you cancel Touch ID function ? If you did can you say how you did ?
由完成的 分享
添加一条评论
I'm having the same problem, did you find a solution? My battery is draining so fast because of my cracked touch id button.
这个答案有帮助吗?
得分 0
添加一条评论
would swapping the tiny chips from one touch id (broken) to second hand one ??
thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
czadra 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 33
过去 30 天: 148
总计 16,201
