跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy J2 是一款于 2016 年 11 月发布的 Android 智能手机。
Samsung j2 charging problem
my Samsung j2 is not charging can I fix the port
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Display change
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
Just verifying that you tried a different, compatible known working charger, charger cable or connected the phone to a computer and also visually inspected the charge port using a strong light and a magnifying glass to check if the port was blocked with lint etc preventing a good electrical connection, to prove that the charge port may be the problem, as you didn’t say? If the port is blocked then try using a vacuum cleaner to suck out the debris. Do not use a metal pin or probe to get it out as you may damage the pins.
If you have checked all the above and determined that it may be the charge port then here’s a video that shows how to replace the USB port The supplier linked is an example only to show the part and cost. There are other suppliers online that may suit you better. Search for Galaxy J2 USB charge port dock connector, to get results.
You will need smd soldering skills and tools to do the repair.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
calstyle99 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 42
总计 1,085
