跳转到主内容
Repair guides and support for wired or wireless devices that provide internet connectivity.
status and wlan blinking continuously
So I have a D-link wireless router DI-524 and for some problem the status and wlan parts of the router seem to keep blinking/ flashing continuously and i cant seem to connect directly to the internet with the blue cable. I have to use another internet cable instead.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
Jordan, can you please explain a little more about the "another internet cable instead."
Status LED – a blinking light indicates that the DI-524 is functioning properly. WLAN LED – a solid light indicates that the wireless
segment is ready. This LED blinks during wireless data transmission. Have you tried a reset of your router?
完成的
the regular cable you would normally use
blue cable is the one from modem to router
yes held it for 15 secs
完成的
So what other cable do you have to use to connect? How do you have it hooked up? Is your router working if you connect a cable to your computer?
完成的
So what other cable do you have to use to connect? I can use the blue cable that is connected from my modem to the router or i can connect a regular grey cable from router to computer.How do you have it hooked up? modem to router to computer basically.Is your router working if you connect a cable to your computer?yes what i usually do to get internet.
完成的
So it is your wireless that is not working?
完成的
显示更多的1条评论
添加一条评论
1个答案
已选择的解决方案
somehow i solved the problem. thanks for all the help
这个答案有帮助吗?
得分 0
1条评论:
How did you?
完成的
添加一条评论
添加你的答案
Jordan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 18,962
