跳转到主内容
加入维修社区 - 创建账户
Xbox 360 是微软于2005年11月22日推出的第二代电视游戏主机。
Optical drive will not open
I followed the repair guide for this issue, though the optical drive still will not open when the button is pushed. I can hear it trying and was able to get it to work once with the help of a spudger. Is there a common issue that I may be overlooking? I cleaned the rails, as well as the rubber belt that controls the movement, but nothing seems to be working.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Rubber belt get old and take a set especially if not used for a while. Cleaning doesn't help unless they are still soft.
Start by replacing the belt. If that doesn't work, there may be cracked plastic gears slipping on their shaft. Plastic does that when it gets old.
这个答案有帮助吗?
得分 1
添加一条评论
I have this problem as well what I did was to hold down the button.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
TYLER GOODWIN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 168
