跳转到主内容
加入维修社区 - 创建账户
三星 Galaxy A71 是一款由三星电子制造、隶属于 Galaxy A 系列的安卓智能手机。该手机于 2020 年 1 月发布。 版本:SM-A715F/DS, SM-A715F/DSN(全球版), SM-A715F/DSM(俄罗斯版)。
A71 Power Connection Port
The power port/plug-in on A71 does not connect properly. I have tried several cables, but the phone doesn’t have that little snap/click anymore and the cable may or not be connected for charging. It also seems to have become progressively worse. Can this connector plug in be replaced?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Hi @lawstn ,
The easiest option is to replace the USB charging dock board (supplier example only to show part and possible cost).
Here’s a video that shows how to replace the board. The board can be seen being removed at 2:56 minutes into the video.
There are other suppliers online that may suit you better. Just search a Samsung Galaxy A71 USB charging port dock connector board.
If doing this yourself seems too daunting, contact a reputable, professional mobile phone repair service and ask for a quote.
这个答案有帮助吗?
得分 1
1条评论:
I had a problem with my Galaxy A71 USB-C port and intermittent charging. What I thought was a bad phone charging port, since it acted the same way with multiple cables, turned out to be nothing more than an accumulation of "pocket lint". in the port. Careful scraping with a wooden toothpick followed by a blast of canned air rendered it like new again!
由完成的 分享
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
It’s full of dust and needs cleaned out. That’s why your not getting that click to confirm the chargers in correctly. Use something with a fine tip to remove the debris keeping away from the pins in the centre. If your not confident find a shop to clean it out for you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 26
总计 1,786
