跳转到主内容
加入维修社区 - 创建账户
Vizio e480i 电视是由 Vizio, Inc. 生产的一款 48 英寸电视。Vizio, Inc. 于 2002 年在加利福尼亚州成立。Vizio e480i 属于智能电视,可通过型号 E480i-B2 进行识别。
Are power supplies interchangeable?
MODEL NUMBER p702ui-b3
It wont turn on. No lights sounds anything. So we are 90% sure it is the power supply especially after looking inside. I have seen some places say you can interchange certain ones but I'm not sure how to figure that out? The power supply in the TV currently is out everything or astronically too expensive. So I'm hoping to find a different one I could use instead. Any help with how to figure out which ones would work?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Generally, most PSUs are very specific to the device. Some TVs have the same unit in a series with different screen sizes or functionality, but then it is the same board so the price is the same. Finding a different, cheaper PSU is mostly not possible. What you might do is to open it up and carefully inspect the capacitors of bulging units. Any convex top is an indication of a failed or failing cap. Those can be individually replaced at a far cheaper rate.
这个答案有帮助吗?
得分 1
添加一条评论
You can interchange the power supplies but there's a few things you'll need to check first. The output voltage cannot be more than three volts higher than the original, the polarity on the device side must be the same, and the plug on the device must be the same size.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
daisha jones 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 766
