跳转到主内容
加入维修社区 - 创建账户
第三代 C/K 皮卡车的维修指南和技术支持。
Cylinder 1 backfire through intake
78 gm 350 5.7 Cid. 4 bolt main Backfire through intake/carberator.
Rods are good, even compression
New distributor, timing gears/chains, plugs, wires, fuel lines, fuel filter, new edlebrock 650cfm carb, lifter springs don't appear to have any wear (push test). When I disconnect cylinder 1 plug from distributor, I know longer have back fire.
My thoughts are a potential whiped cam lobe on cylinder 1 or a single bad lifter. Lookin for help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Before opening the engine, check the fuel injection needles inside the carburetor, I have the same problem. One of the needles is loose and is injecting more.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kenneth Sapp 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 139
