跳转到主内容
加入维修社区 - 创建账户
Meta Quest 2(前身为 Oculus Quest 2)于 2020 年 10 月发布,是 Oculus Quest 的继任者。
Why does my left controller stick have drift?
I was playing the walking dead: saints and sinners for the first time and I noticed I was slowly strafing to the right. I took it as the game's push mechanic and just kept playing. I then hopped onto vrchat, and truly noticed the stick drift. I haven't seen any repair guides for the quest’s controllers, so I'm wondering if anyone knows a fix?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 11
4条评论
I have been having this too. I push forward and then i start walking backwards, either down through menus or when I'm walking around. blowing on it helped for a few weeks until it didnt. im dreading sending it in because i use my quest 2 every day.
完成的
Same here, whenever I use VRChat it would move backward or sometimes left or right, which makes it impossible to move in the direction I want to move.
完成的
I am having the same issue in Resident Evil 4 and Pavlov, actually every game where I need to use movement (Left controller thumbstick). If anyone know how to fix it please share. I'll be greatful.
完成的
Not sure what to do for sideways stick drift but i have front/back stick drift on my left controller, i switched my thumbsticks so itd be my turning stick since it doesnt drift sideways, rolling the thumbstick while pressing it in also seems to work for short periods of time.
完成的
添加一条评论
1个答案
最有帮助的答案
You could try spraying in some deoxit fader f5 around the edges of the . (or any other contact cleaner that contains carbon dust) I did that on my joy cons for my switch and it fixed the issue.
这个答案有帮助吗?
得分 6
添加一条评论
添加你的答案
Lalt Papal 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 38
总计 4,331
