跳转到主内容
加入维修社区 - 创建账户
家庭电气安装是一个复杂的电气组件系统,将电力引入家中并分配到各个插座、电器和照明灯具。
shed light switch not working
shed light switch suddenly stops working, have changed it twice. power to switch and lights work if bypassed. what is causing switch failure? Not used often
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @underdog500 ,
How many lights are connected to the switch?
Have you checked that the current rating of the switch is appropriate for the number of lights connected?
Does the switch smell burnt at all?
由完成的
添加一条评论
1个答案
Since it is located in a shed it isn't in a controlled environment like inside a house. Humidity and such play large factors. I would recommend an enclosure like this: https://www.homedepot.com/p/Greenfield-W...
I've installed them before, they're very easy, and your switches should last longer since they'll be more protected. Also, check and sure nothing has been leaking in/on the switch or electrical box.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
william bassett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 325
