跳转到主内容
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
83 个问题 查看全部
Why does my TI-84 Plus CE graphing calculator die fast?
When charging, the battery indicator on the screen stays the same at about 3/4 of the rectangle. I left it for about 5 hours and it still isn’t fully charged. When I unplug it to use it for 5 minutes, the calculator battery instantly drops to about 1/4 of the rectangle.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
As brandon k pointed out, that behavior likely means the battery is shot and you’ll need to replace it. There’s a guide to help you with that here: Texas Instruments TI-84 Plus CE Battery Replacement
Be careful because the battery may have swelled and could cause a fire if you mess with it too roughly.
这个答案有帮助吗?
得分 1
添加一条评论
From what you described it sounds like the battery(s) need replaced.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sunshine 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 38
过去 30 天: 124
总计 2,872
