跳转到主内容
加入维修社区 - 创建账户
这是 2018 年末款 MacBook Air 小幅升级版的维修信息和指南,其型号 (A1932) 和 EMC 号 (3184) 均相同。此型号配备了原彩显示技术 (True Tone) 并对电池进行了微调。
Left hand speaker muffled and staticy
Okay, my MacBook Air’s left-hand speaker is weird. It very very muffled and full static when compared to the right.
I thought it could be water damage and decided to replace it. I did that myself and it all went well and then went to check and no change on that speaker. It was the same as before not even a single change or improvement.
I ran Mac diagnostics, nothing came up. I also reset NVRAM/PRAM as someone had suggestion that might help. Still nothing. I’m at a total loss of what to do.
Also, I am 100% sure when I got it first it was working fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
What do you hear when you plug in a good set of headphones in via the headphone jack? Use the balance control to bias which headphone is playing. Do you hear it with the headphones?
If you do then the MacBook Air 13" (Late 2018-Mid 2019) Audio Daughterboard or MacBook Air 13" (Late 2018-Early 2020) Audio Daughterboard Cable to the logic board is the issue. If its clean on both sides, then the logic board speaker cable connector has a problem.
Review this guide: MacBook Air 13 英寸 Retina 显示屏 2018 年末款音频板更换
Replace a torn or damaged cable connecting the logic board to the audio daughterboard containing the headphone jack and connectors for one speaker and the Touch ID sensor.图片
产品
$19.99
Replace a corroded, dirty, or damaged headphone jack by swapping in an audio daughterboard containing the headphone jack and connectors for one speaker and the Touch ID sensor.图片
产品
$59.99
这个答案有帮助吗?
得分 0
5条评论:
Earphones have no problem with this. Only occurs when I use the in built speaker,
完成的
Look at the logic board for corrosion.
完成的
@danj I am pretty sure there was none since I did open up when replacing the speaking thinking that was the issue, and saw nothing much there in terms of it looking diffrent.
完成的
I think you'll need to bring your system into someone who has the skills to diagnose your issue. There is a limit on what I can offer for help.
完成的
@danj Thank you. Just wanted to exhaust all options before I did that in case it's something I can fix on my own. Really appreciate you taking you time to try and help me.
完成的
添加一条评论
I had the same problem with 2 Macs, the solution was to clean the grille with a dry/clean toothbrush. The issue was that the micro-holes were blocked, which can be confirmed by passing light through them.
I could diagnose the problem by connecting the speaker without installing it, I leave it carefully hanging and it sound really loud.
I attach a photo of the blocked micro-holes.
这个答案有帮助吗?
得分 0
2条评论:
@oliversi - To many bread crumbs! 😆
完成的
it acted more like a cheese grater :)
完成的
添加一条评论
添加你的答案
SeanErik 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 28
总计 751
