跳转到主内容
加入维修社区 - 创建账户
小米 Mi 8 安卓智能手机由小米公司生产,于 2018 年 6 月发布。
No GPS after screen replacement
So after I replaced the display on my MI 8, the GPS is not working at all, everything else is fine (wifi and bluetooth as well). The new display came with the frame/housing as well, so I had to move the mainboard and all to the new one.
One thing is interesting is that it looks the new frame is missing a few contact points. could this be the problem? How can it be solved?
Photo:
btw, just to be sure, I moved back to the original frame + connected the new display, and this way the GPS is working fine. One solution would be to just take off the working LCD and apply to the original frame, but I’m afraid I’d broke the display while taking off…
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
i notice two other differences as well. Not sure how significant they are. But its safe to say some or all.of these differences are what is killing your GPS. I suppose rather than breaking your new display, can you take the contacts off the old case and put them in the new one?
这个答案有帮助吗?
得分 1
1条评论:
Unfortunately, these contacts cannot be taken off, as they are "part" of the (metal) frame.
完成的
添加一条评论
I have the same issue on my device, tho I got mine in a used state and I dont know if the screen has been replaced (but I assume it is). Can you see where those contact pins are on the motherboard and add a small piece of tinfoil so they touch with the new frame?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mate P 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 16
总计 1,058
