跳转到主内容
加入维修社区 - 创建账户
How to replace the battery?
Looking for assistance in replacing the battery.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
To take this apart, use a pry too on the bottom cap. You can see the rubber under the cap. Pry this off and gently remove the rubber sleeve. Remove the torx screws open the case. The batter is the round thing. I cut the plastic and foam off of it and peeled the metal nickel strips off the old battery and welded a new one in. You can also use Solder if you broke the nickel strips as I did. Wrap it back up in some foam tape so it doesn't rattle. Reassemble.
这个答案有帮助吗?
得分 1
1条评论:
Thank you so much.
由完成的 分享
添加一条评论
What battery did you use to replace this speaker?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jimmy 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 42
总计 2,206
