跳转到主内容
加入维修社区 - 创建账户
The Golf Mk4 was first introduced in August 1997, followed by a notchback version (VW Bora or, in North America, again VW Jetta) in August 1998 and a new Golf Variant (estate) in March 1999.
reset radio golf 2003
Have a Volkswagen Golf 2003 model. How to reset the radio?
Have some errors I believe can be solved with a reset..
The problem is, I use the up-down buttons and switch radio station with nothing happens ..
Antenna is replaced it must be the radio
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
and always make sure that you have the right reset code.
完成的
This has been tried!
It does not work. Electricity was off for 30 minutes, and the radio did NOT ask for the radio code.
完成的
This question was migrated from http://meta.ifixit.com/Answers.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
take of the ground wire from the battery for about two minutes, then put it back on. This should do a reset not only to the radio, but to the whole CAN-Bus system as well.
这个答案有帮助吗?
得分 3
1条评论:
+flat battery/disconnecting etc has always reset my radio!
完成的
添加一条评论
添加你的答案
Kjetil Pedersen 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 39
总计 10,662
