I cant find the cursor it has disapeared and I need it to be found!?
I need to know how to find the cursor to my asus vivobook it has disappeared and I have tried everything pleaseee help me
First connect a standard mouse to the laptop and then make sure the Touchpad function is enabled in Windows settings.
Click on [Start menu],
Select [Settings]
Select [Devices]
Select [Touchpad],
Make sure the Touchpad function is [On]
Then use the function key (hotkey) to enable/disable the touchpad function to ensure the Touchpad is not in the disabled status.
Note: The hotkeys function may be different based on different models, please refer to the User Manuals. Or, you can find the hotkeys location whether there is a touchpad icon (it usually located on F6 or F9 key), then press fn Key + touchpad hotkey to enable/disable the touchpad.
The other thing to check is the BIOS. Press the "F2" key as your computer is booting up and select "BIOS Settings" from the menu that pops up. Look through the settings until you find the Touchpad setting and make sure it is enabled.
If after all that it still doesn’t work then replace it:
Asus VivoBook E203MA-TBCL432B TrackPad Replacement
Hope that works. Let us know how it goes or if you have any more questions.
这个答案有帮助吗?
Yes, it works. External mouse works well and settings of touch pad was off. Thanks a lot, Mark.
过去 24 小时: 104
过去 7 天: 834
过去 30 天: 3,297
总计 26,074
