跳转到主内容
Asus VivoBook E203MA-TBCL432B TrackPad Replacement
你所需要的
  1. Asus VivoBook E203MA-TBCL432B TrackPad Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
    • It will be easier to replace the battery if the laptop is closed.
  2. Asus VivoBook E203MA-TBCL432B TrackPad Replacement: 步骤 2 中的图像 1,3 Asus VivoBook E203MA-TBCL432B TrackPad Replacement: 步骤 2 中的图像 2,3 Asus VivoBook E203MA-TBCL432B TrackPad Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
    • Remove the two 7 mm Phillips #0 screws.
    • The 8 screws marked in red are all of the same length, 5 mm, and should not be interchanged with the two longer 7 mm screws marked in orange.
  3. Asus VivoBook E203MA-TBCL432B TrackPad Replacement: 步骤 3 中的图像 1,3 Asus VivoBook E203MA-TBCL432B TrackPad Replacement: 步骤 3 中的图像 2,3 Asus VivoBook E203MA-TBCL432B TrackPad Replacement: 步骤 3 中的图像 3,3
    • Insert the iFixit opening tool in between the back panel and the rest of the laptop.
    • With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
    • Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
    • Make sure to use a plastic tool, not a metal one, so that you don't scratch the panel.
  4. Asus VivoBook E203MA-TBCL432B TrackPad Replacement, Battery: 步骤 4 中的图像 1,3 Asus VivoBook E203MA-TBCL432B TrackPad Replacement, Battery: 步骤 4 中的图像 2,3 Asus VivoBook E203MA-TBCL432B TrackPad Replacement, Battery: 步骤 4 中的图像 3,3
    • Now that the back panel is removed you can clearly see the battery and all of its connectors.
    • Begin by removing the silver ribbon cable along the back of the battery.
    • To disconnect it from the motherboard, lift the black tab on the Zero Insertion Force (ZIF) connector up and pull the cable away using the blue tab.
    • Disconnect the ribbon cable from the left side in the same way.
  5. Asus VivoBook E203MA-TBCL432B TrackPad Replacement: 步骤 5 中的图像 1,1
    • Remove the red and black wire along the bottom of the battery.
    • This does not need to be disconnected, only removed from the clamps along the bottom of the battery.
  6. Asus VivoBook E203MA-TBCL432B TrackPad Replacement: 步骤 6 中的图像 1,2 Asus VivoBook E203MA-TBCL432B TrackPad Replacement: 步骤 6 中的图像 2,2
    • Using the Phillips #0 screwdriver, remove the two 3 mm screws located at the top and left side of the battery.
  7. Asus VivoBook E203MA-TBCL432B TrackPad Replacement: 步骤 7 中的图像 1,3 Asus VivoBook E203MA-TBCL432B TrackPad Replacement: 步骤 7 中的图像 2,3 Asus VivoBook E203MA-TBCL432B TrackPad Replacement: 步骤 7 中的图像 3,3
    • Gently lift the battery being mindful of the one cable still connected to the motherboard.
    • With the battery lifted, pull the remaining connector going to the motherboard up, it should come out with little force.
  8. Asus VivoBook E203MA-TBCL432B TrackPad Replacement, TrackPad: 步骤 8 中的图像 1,3 Asus VivoBook E203MA-TBCL432B TrackPad Replacement, TrackPad: 步骤 8 中的图像 2,3 Asus VivoBook E203MA-TBCL432B TrackPad Replacement, TrackPad: 步骤 8 中的图像 3,3
    • Insert the iFixit tool underneath the cable that is attached to the trackpad to unclip the cable.
    • Using the reverse tweezers, remove the ribbon cable and the tape that is attached to the trackpad.
  9. Asus VivoBook E203MA-TBCL432B TrackPad Replacement: 步骤 9 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the three 2.0 mm screws above the trackpad.
  10. Asus VivoBook E203MA-TBCL432B TrackPad Replacement: 步骤 10 中的图像 1,3 Asus VivoBook E203MA-TBCL432B TrackPad Replacement: 步骤 10 中的图像 2,3 Asus VivoBook E203MA-TBCL432B TrackPad Replacement: 步骤 10 中的图像 3,3
    • Insert the iFixit opening tool under the frame that surrounds the trackpad and carefully pry the frame of the trackpad up.
    • Now that the track pad is lifted up, gently slide it out by pulling it towards the hinges.
结论
2等其他人完成本指南。
Khadijah Sulail
于11/16/19注册
415 声望
创作了3篇指南
团队
IUPUI, Team S3-G3, Wilson Fall 2019 IUPUI, Team S3-G3, Wilson Fall 2019 的会员
IUPUI-WILSON-F19S3G3
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 15
总计 928
