跳转到主内容
加入维修社区 - 创建账户
小米旗下 Amazfit 品牌的方形塑料智能手表,发布于 2017 年。
Battery replacement on Bip
Does aynone tried to replace the batteriy in the watch? It seems my watch battery capacity reduced. Last depleeting cicle took only 15day but usualy it took 30-45day to drop to 15%. What kind of battery can be used to replace the original?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
5个答案
最有帮助的答案
Replacement Bip battery
https://www.ebay.co.uk/itm/204240393865?...
这个答案有帮助吗?
得分 1
添加一条评论
Hi there! The battery used on the Bip (model A1608) is a 200 mAh lithium ion battery. I’ve also been having issues with my Amazfit smartwatch regarding battery charge depletion. I think it may be something to do with your plug adapter or the fact you may have left it on the charger a bit too long after it reached maximum charging capacity.
这个答案有帮助吗?
得分 0
1条评论:
I think it's the BMS. Mine drains in 5 minutes but you can still turn it on with long press. Then recharge for minute and it says 90% again.
由完成的
添加一条评论
I suspect this is some software update result not really the battery. I already bought a bips and that have even shorter battery (tooks about 9day to depleet). So the old bip sits in its onw box. After about 6mo I checked what is the battery status and put on charger it was about 85%. If the battery would bad I suspect it would not even turned on.
这个答案有帮助吗?
得分 0
添加一条评论
wher can i get amazfit bip u pro battery.???
这个答案有帮助吗?
得分 0
添加一条评论
Battery replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dimitryj Tyer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 80
总计 4,952
