跳转到主内容
加入维修社区 - 创建账户
小米 10 是小米于 2020 年 2 月发布的中端智能手机。它配备 6.67 英寸 AMOLED 显示屏、108 MP 主摄像头、屏下指纹传感器和 4780 mAh 电池,并搭载高通骁龙 865 处理器。
Power button is stuck
How easy wwould it be to replace the power button on this device?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
I know is an old question and most probably Jismy is no longer needed it.
The answer is: The process is a little complicated similar with changing battery process, but you have to take out also the main board, because the power and volume rocker buttons are on the same ribbon cable which is connected beneath the main board.
I replaced one year ago that ribbon cable.
As a starting point for the process you can use the battery replacement guide: 小米 Mi 10 电池更换
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jismy :D 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 44
总计 1,433
