跳转到主内容
加入维修社区 - 创建账户
The Nikon Coolpix 995 a 4 x optical zoom, 38 - 152 mm with rotating handle was released in 2001.
camera won't turn on, via battery or AC adaptor
Hello! Camera appears dead and I'm pretty sure I need to take it apart. Under Troubleshooting Tips C. Layman has posted "If none of the above solutions work you might have a hardware problem which could be a loose wire or connection internally. Follow the step by step instructions on disassembly provided." I can't seem to find the disassembly instructions - can you provide a link? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
My first suggestion would be that you take a good look at your battery. Make sure the pins are not corroded or bent. Change the battery as well or try to charge your in a separate charger. Make sure that the cable to your camera is in good working order and that the port for the cable is clean. If any of this fails, you can download the complete service manual for your camera right here Hope this helps to get your camera going again. Good Luck
这个答案有帮助吗?
得分 2
添加一条评论
I have the same problem with my Coolpis S8000. It suddenly stopped to charge att was unable to transport via USB. This happened when I used other usb Cable as the original. Now the camera works if i puts a full charged battery in it only. I Think it had som problem even Before like not charging very well. Could this be a eassy fix?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nina Sherwood 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 1,675
