跳转到主内容
加入维修社区 - 创建账户
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
Why is the boot screen blank?
So I’ve worked on several Macs over the years and I’ve never seen this before and can’t figure it out. I have a 17” PB 1.67. It works fine, but there is no boot screen or chime. It’s blank like what you would see when you have a non flashed graphics card in your Mac Pro. I’ve done all the normal resets and key combinations. I’ve even booted into open firmware and did the reset-all command which I only know worked because the Mac rebooted. Any thoughts? Something I can key into the terminal to bring back the Apple logo? I’ve erased and re-installed OS X as well. Anyone else seen or fixed this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Your facing the dreaded dead PRAM battery issue!
Follow this guide to get to it PowerBook G4 Aluminum 17" 1-1.67 GHz PRAM 电池与 USB 板更换 which is located under the optical drive.
这个答案有帮助吗?
得分 0
1条评论:
Dan, I will check that PRAM battery. Thanks! I probably wouldn’t have thought of that since it held the time and date with the main battery out and it’s the only thing I haven’t done.
由完成的
添加一条评论
Have you checked the battery? Or there is something wrong with some certain apps.
This page may be helpful: https://www.minitool.com/data-recovery/f...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
brandonbanfield 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 19
总计 420
